weirdguywithaknife
When using the sub channels,ie. ch 21 and 54 of the privacy codes, does that alter the frequency used? Is there a listing of them if so?
Bubble pack radios tend to only do PL (Motorola for CTCSS) some guys will use DPL (DCS/DTCSS) to keep bubble pack radios from being able to hit their repeaters or interrupting their simplex comms.
I'm not too familiar with how bubble pack (22 ch radios often bought in pairs) do their frequencies. If ch 21 462.700 MHz then I'd see it how Icom organizes their GMRS channels (channel 7).
Fyi, most of the GMRS/ FRS bubble packs on the market now include both PL and DPL and a few are even repeater capable like the MR350's
73,
n9zas
Didn't see the users manual on the MR350 mention repeaters but it did mention PL and DPL (however it did not define how their number correlates to which PL/DPL). I know some of the newer bubble packs will do repeaters but they won't do split tones. Then again, going split tones is just kind of mean…
I purchased a MR35* and returned after testing it was the yellow floating radios, two for 73 after tax. channels 1-7 FRS 1/2 watt. channels 8 and up were GMRS at 1 or 2 watt's the last 7 channels on the radio were already set up in pairs. 467/462 for repeater use. These radios were easy to set up. but very poor for anything other than very local use. "Do not use these radios in the cab of your truck or car" since they include the FRS channels, they are not allowed to have a removable antenna. Consider a CCR "cheap Chinese radio" There are many to chose from. CCR's include a removable antenna, much safer to attach to a mag mount antenna and use in your truck or car. they also transmit up to the 5 watt's allowable by the FCC on GMRS HT's. Some claim since these radios are not part95 cert. they are not legal to use, However I believe there is much room for interpretation. I also believe that when it comes to emergency communications, I want the best radio I can have. Spend as you wish, but do the research first.
yep, all of mine are 4 watts also, although I have a new Kruier radio for my HAM stuff, that claims 8 watt's. I may never know as I can not get the software to install. 4 watt's is a lot closer to 5 than 1 or 2 watt's. FRS use in a car or truck is mostly safe at 1/2 watt but most likely ineffectual as much of the ERP is deflected and not radiated in an efficient pattern. more power does not improve your chances of getting a signal out of a vehicle it only increases your exposure to harmful RF radiation. I consider an external antenna necessary when operating in my truck, or any car. a good mag mount and a CCR with a removable antenna get's the job done.
