motorola 5500 console tones
nhfdcadet
GCT-1
New Hartford, Ct
At work we use motorola 5500 dispatch consoles
the tones in the consoles are translated into codes, like 08DE or A295, i dont really understand why they dont just have the tones put into them in Hz, but i guess thats motorola for you.
So does anybody know how to find out what those tone codes translate into or how to convert a tone into that code?
we can manually encode tones as well but again requires that same 4 digit code
so like if i wanted to put in 1472.9-584.8 how would i find out what the 4 digit code for that is?
thanks
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
thanks
I just scanned through the 5500 console installation manual. There is no paging encoder built into the console system. Instead, the system has provision for connecting an external encoder.
What's critical to answer your questions is to know what brand and model encoder is installed in your system. Then we can begin to make sense of the codes that in turn generate pager tone signalling.
Now, before you try to tell me that the encoder is too in your system and that I'm full of hot air, please consider that you're an operator, not a tech. To you, it's all one neat package that performs all those different functions. And it sure does look that way. But that's not the case. A console like the 5500 marries a bunch of different components and systems into a (hopefully) seamless unit that does whatever you, the dispatcher, need it to do. Individual components that are CONTROLLED by a console include radios, repeaters, voting systems, encoders, decoders, wire lines, microwave links, etc. Each of these components can be from different suppliers so knowing what the components are is very important. There's lots more to it, but I think you begin to get the idea.
So, repeating myself here... Let's find out what make and model of paging encoder is used in your system.
firefive76
Kansas
The MCC5500 DOES support 2-tone paging and several other formats. The console code for 1472.9 and 584.8 is 0701
PM me your email and I can send you the translation guide for the 5500.
SteveC0625
I humbly stand corrected. There is virtually no mention of the built-in paging encoder in the install manual. However, after downloading and reading through several other large documents, I found the charts in the system database manager for it.
It's complex, and figuring out the actual tones from the paging code is painful.
