Motorola APX 1000 clean codeplug
lifsvr25
Northern Wisc
In search of a clean apx 1000 vhf codeplug to over-write a password protected one. Single unit I got in a box of junk from a FD I just did some reprogramming for. Battery pins are bad, and have to have a zip tie around the unit to keep it alive. Figured I would make it a conventional vhf scanner, any help greatly appreciated. And yes, radio programming and installation is my weekend side gig, as local angencies appreciate my flexible schedule.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Pretty sure it doesn't work like that.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Nothing super secret in the device, just whanna remove the ability to transmit.
Again, that's not how Motorola radios work. The codeplug is tied to a specific serial number and a specific flash code.
It's NOT as simple as taking a random 'clean codeplug' and blasting it into the radio.
n3obl
ØAES-1056
PA
More than likely it has read and wrote protect enabled. If the firmware low enough you may be able to use unmentioned software to blow a blank codeplug into said radio.
Not say it stolen but I have seen stuff hit surplus markets where either the codeplug was not cleared from radio. Password protection was not removed or still attached to an ask for protection even after clearing the codeplug. Which basically makes the device useless.
