Motorola APX 8000 repeater problem
michael_toth7
I had just purchased a used APX 8000 and was programming it to find that for some reason it won’t hit the repeater. I double checked to make sure the frequency’s were correct and they all are. If I use a direct channel then I can use talk around but you can’t hear other people on the repeater or talk on the repeater. This is happening with all the channels and not just one. Looking for some advice.
cmjonesinc
If you want to post your codeplug I can take a look? Do you have prior experience programming APX radios?
Tech21
Make sure the Tx frequency of the Repeater is the Rx in the portable. Make sure the Rx frequency of the repeater is the Tx frequency in the portable. Make sure you have the correct tpl/dpl codes.
