Motorola Capacity Max Software
zsauve
Oak Creek, WI
Is the software for Motorola Capacity Max a separate software package like how connect plus is or is it integrated into the regular Mototrbo CPS? If it is a separate software package, does anyone know what the part number is for it as I cannot find it under the Mototrbo section on Motorola online.
Firebuff880
Boynton Beach, FL
@zsauve, So your answer is yes.
Like Connect Plus you do not use the base CPS, but you will not find a separate offering or need special option board firmware either. Capacity Max is only programmable through radio manager with a radio manager client in configuration mode.
Depending on the gen 2 (only) model you have you may or may not need an EID for the subscribers.
zsauve
Oak Creek, WI
Thanks for the info! I will have to look into that.
com501
You have to buy a CapMax server and license to get the software. It comes installed on the server. Think large amounts of $100 bills. Stacks of them.
Firebuff880
Boynton Beach, FL
No!
You buy one or more CapMax servers as part of the infrastructure it is the Trunking controller, so usally a primary an secondary (hot standby).
But Radio Manager an MNIS are still distributed through MOL an run on different / your windows boxes not the CapMax controller. Although the controller an Radio Manager are tightly coupled.
You can no longer use standalone CPS or template mode.
