So I just recently got a Motorola CDM1250. Everything works fine, however I can't seem to figure out an issue I'm having with the Home Revert function. In CPS, it allows me to designate 2 Home Revert channels. So I did that for my 2 main channels. Then when assigning functions to the buttons, I put Home Revert 1 on P1, and Home Revert 2 on P4. Home Revert 1 works just fine, when I press P1 on the radio, it goes right to that channel. I cannot say the same for P4/Home Revert 2. When I press it, the radio does nothing. It doesn't even beep or flash. The radio is not reading the function when the button is pressed. I have programmed other functions on the P4 button, and they work fine. I have even tried the Home Revert 2 function on other buttons, and I get the same negative result. The same is for my keypad microphone. No matter what button I assign Home Function 2, the radio does not register it.
Please Help!! Thanks!
