Vertex standard radio programming issues
NavyPhil
Alabama
I have a vertex standard BX6000 that I want to program to new frequencies. I have the proper cabling and software from the manufacture. When I try to upload from the radio the software states “turn radio off and back on to start upload”. I do this and it always comes back with “turn radio on” after I already have. I also did this holing the power and function button under the power button to go to the “pc clone” condition with same results.
Thanks for any help.
Phil
MBill
Vertex has used different approaches with its radios.
Try leaving the radio turned off. Select read from radio
and then turn radio on when it tells you to. This works
for some Vertex radios. If you have a manual check
and see if there are buttons you have to hold while
turning it on. Hope you figure it out.
radiotweester
Oregon
Comport # is correct? Serial or USB. USB you might need to slow down speed. Try both side mic ports. Both should be the same, but...
It is all about timing. The manual or SM are pretty vague about programming as is the Help menu. Read or Write, wait 1/2 second, then power on the radio.
express315
I think you are using incorrect software.
CE49 software does not ask to turn off/on the radio.
Yes, you have to put the radio into PC prog mode by holding the button below Power button while turning radio on.
PM me if you want me to walk you through. I play with this radio model every day.
radiotweester
Oregon
CE49 V5.00 Same PF1 for upload and download.
If you're using the service software it is radio specific VX4000 and VX5500/6000 versions.
