Motorola CDM1250 programming help
Bean791
I’m trying to program a CDM1250 using windows 7. I have used this machine and same software to program HT1250s and EX600s. I have a USB cable that plugs into the mic jack on the radio. I keep getting an error saying to check the rib and connection to the machine. I am using the correct port. Any suggestions? Possible it’s just a bad programming cable or should I attempt another computer with a different operating system? Any advice is appreciated.
Ant9270
The Green Weenie
Check the driver in device manager, under coms and ports. Ensure that the programming cable is being recognized. Unfortunately USB cables can be extremely sporadic ESPECIALLY if they’re PL chips. Once you’ve ensured the driver is being recognized, check your com port settings in CPS. If all above don’t work there is a chance it’s a defective cable.
BITT211
ELMA , N.Y
try MAXTOP APCUSB - GM300-UF [ FTDI CHIPSET PROGRAMING CABLE] READ RADIO ,CDM1250 , PERFECT , JUST PLUGGED IN USB PORT READ PORT AND RADIO , LIKE $ 17.00 .
SpugEddy
Camden County South Jersey
If you're using Prolific driver, make sure the driver
is version 3.2.00. The file name on the web is P3200.exe
I have 3 CDM1250's and 1 CDM1550. If the driver auto updates, I get
that error and I have to roll back to 3.2.00
Bean791
I have that driver installed but I am going to try re installing. Strange thing is, the first time I tried reading the radio, the radio beeped but since then I can’t get it to even beep again.
Bean791
Turns out the driver was the issue. My driver was too new. The 3.2.00 driver did the trick.
