Motorola CM 300 Programing
PCramton
I have a CM300 radio and im trying to get it programed for my POV* the tower/frequency we have uses a QT/DQT encoder and decoder and one of ENC and DEC is D261N how would I go about inputting that into my radio on the frequency
clbsquared
Isle of Wight County
That’s a DPL code. Motorola uses TPL and DPL Select DPL and it should populate the list of digital codes. There should be a drop down for PL Tones near the same area that you input your frequencies.
PCramton
what does that look like in the CMS program. I cant seem to find it if anyone can help
EWC_BDN
right under your frequencies. it probably says CSQ or TPL right now. you need it to say DPL. Then the code is just 261. D is DPL, N is normal (so you do not check the box that says DPL invert because you don't want that!)
