stewartp5
Hello group,
I have a couple of of legacy cp200, and one legacy cp200xls two-way radios that I am trying to program. I have a couple cp200d two-way radios that are already programmed. The problem is that I am having a problem finding the programming software, I checked with several motorola dealers, and I noticed that the software for the legacy cp200, and cp200xls radios was listed as discontinued (I am assuming that this is due to the age of the radios, and the fact that the radios are also disconinued).
I have three questions concerning how to clone the cp200d with legacy cp200, and cp200xls two-way radios
1. will the cloning cable for the legacy cp200 work with the cp200xls, and the cp200d two-way radios?
2. do I have to find a cloning cable that is both micro usb,and micro tip ring sleeve combination cable? if so does this cable exist? if so does anyone know where I can purchase it from?
3. will any cable that is a compination micro usb combination micro tip ring sleeve connector work?
Thank you,
Peter Stewart
Thank you,
Peter Stewart
