Motorola CPS question
Enjoi19
Ontario, Canada
Unfortunately, you are VERY much digging a hole right now. If you are attempting to use this as a scanner, you have programmed it very, very wrong. There are many guides out there for this. You will not find any help here from users and the next posts will likely be telling you to put the radio down and get a scanner instead.
If you are getting "out of range", it has attempted to affiliate with the control channel. Unless you're an authorized user on the system, you are now entering very dangerous waters.
K4EET
Chaplain
Severn, Maryland, USA
Sell the Motorola APX 4000 and get yourself a Uniden SDS-100 or SDS-150 before your APX gets bricked. At that point in time it will be a stylish HT paperweight. Simultaneously, you may be ordered to appear at the above building. Make the right choice before bad things happen.
Here, I'll do it:
PUT THE RADIO DOWN AND GET A SCANNER INSTEAD.
Your soon to be expensive paperweight is trying to affiliate with the radio system.
Please, there are many of us system administrators on this site, and we are really trying to help you out here. Stop what you are doing. Your radio affiliating with the system can take resources away from legit radio users. Your radio can be remotely killed. Piss off the system admin enough, and the FCC will drop by your house and help you choose the right path for the rest of your life.
Don't believe me?
Ask this guy how it turned out for him:
  • DOC-389269A1.pdf
