Motorola GP400 UHF Help Please!
RadioKid47
Somewhere with a radio in my hand
I have a motorola gp300. I bought a new battery for it. Popped the battery in, plugged it into the charger and the red light was steady. Left it charging over night. Took the radio. Tried to turn it on. It didn't turn on. Please help me. Also please excuse any typos. Doing this on my phone.
C138NC
Tactical Taco Consumer
NC Taco Command
I was about to say GP400?!
First where did you get the radio from?
How was it taken cared of by the previous owner(s)?
Did you check the contacts when you took the battery off, it could be bad connectors or more of an inside issue, if the battery is new then you can hold onto that but if its the radio itself, it could be repairable if its something minor.
obijohn
The fuse on the radio circuit board is probably blown. Unless you are handy with working with circuit
board soldering/desoldering, you should take it to someone who is experienced with this.
If you take it to a Motorola dealer, it will cost more to repair than the radio is worth.
