Motorola gr1225
wesley2099
I’m looking for some help, I have acquired a Motorola gr1225 repeater with a control board installed as well. I am new to this but trying to figure out if this unit has a duplexer installed internally or not. I can not see one under the cover just an open empty mini uhf connecter off the radio. I briefly turned it on seems to power up and work and I do hear a beep when I try to kerchunk the gmrs repeater.
petnrdx
Hudson, FL
The duplexer should be in a slot in the side of the cabinet.
Left side when looking from the rear.
DON'T make it TX without an antenna or a duplexer, you might fry the transmitter if you do it too much.
The Mini-UHF you see on the end of the radio chassis WITHOUT heat sink fins is the RX.
The opposite end is the TX connector, the end WITH the kinda gold colored heat sink.
The power plug also is on the TX end.
The radio chassis should be installed with the TX (heat sink) to the rear, and RX towards the front panel.
You can't really miss seeing the duplexer if it is there.
