Motorola HSN1005a
toonman4
McHenry Co.
I just pick up a Moto HSN1005a amplified speaker but it did not come with any documentation.
Does anyone know the pinouts on the connector?:confused:
there are 6 pins but only 5 have wires attatched.
looking into the connector with the locking clip on top the wires are as follows:
Empty | Red | Red
Blue | Black | Red
K8PBX
Washington, Michigan
Hope this helps...
toonman4
McHenry Co.
I found that pic also but I'm still a little confused
I got the center 2 pins as power
the 2 left pins are actually tied together
am I to connect 1 speaker wire to the upper right pin and 1 to the upper center?
the lower right pin has no wire on it
I'm trying to hook this up to my scanner and don't want to screw it up
fineshot1
NJ USA (Republic of NJ)
Where did you find a mate connector for that odd molex size? I just chopped it off and your left with a red(+12), a black(ground) and a blue(speaker audio input). I directly wired it into the radio I am using and it works great.
toonman4
McHenry Co.
Fineshot1
I didn't find a connector
I was going to call Motorola (corporate is only a 1/2 hour from me) to see if I could get one but I ended up chopping it off and doing as you did
chgomonitor
Silent Key
Chicago
-A hook-up cable came with my speaker. I left it attached at the speaker end. At the other end I cut off the jack and split out the wires from the cable jacket. This worked for me with no hum on the audio:
RED + 12 Volts (positive) = to external power supply / battery
BLACK - 12 Volts (negative) = to external power supply / battery
BLUE - Audio input (inner conductor / tip) = cabled to external speaker jack on radio
Bare silver shield wire - Audio input (outer conductor / ring) = cabled to external speaker jack on radio
Quite loud and fairly clear up to near maximum volume. When you reach ear splitting levels you get a fair amount of distortion.
Happy Scanning! - Ted
