Motorola MT1500
RFAS251
I have just aquired a motorola mt1500 vhf 1.5. i am told and my research tells me i should be able to do 4 lines of 12 characters each. in the software i can only manage i think 14 characters total: ie: if line 1 is "zone 1" line 2 which would be my channel name can only be 8 characters. is there a setting i have wrong? is it a firmware thing? i am running the most recent version of astro 25 portable cps. any help would be appreciated as im stumped by this. thank you all in advance
n3obl
ØAES-1024
PA
there is one line for channel and or zone based on settings. Usually 3 characters for zone and 9 for channel name.
Line under is for radio id or temp message display like id number etc. thats it.
RFAS251
Ah OK then. I was lead to believe it was 4 lines of 12 characters and it was user programmable. Not the end of the world I was just trying to figure it out. Thank you much for the info
K2NEC
39A
The model 2 (and model 3) XTS2500 has 4 lines of text yes, but only 1 of which is zone/channel. Lines 3 and 4 are used for the soft buttons under the display. But since the MT1500 is only Model 1 or 1.5, this isn't applicable to you.
RFAS251
that clears it up thank you guys so much for the info. i will make it work as im happy to just have a screen and some letters which is a major upgrade from my last unit
