Motorola NAC ?
nokones
Sun City West, AZ
NAC means Network Access Code which is used on conventional P25 Astro Digital channels like PL/DPL is used for analog channels. The CPS default NAC is 293. For my Astro Digital channels, I just stay with default 293 for both transmit and receive settings.
K2NEC
5F6
That is not what the OP asked
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
I know that so, what's your point?
Lmao. You didn't actually answer the OP question, you wrote a word salad that wasn't even on topic. Nobody cares how you program your radios.
BTW, only lazy people use defaults like $293, TG 1, RID 1, CKR 1 or KID 1.
Do you use 67.0Hz for all your analogue channels?
nokones
Sun City West, AZ
If the repeater channel requires 67.0, then yes and one does. And there are some simplex channels that I have to use, not of my own, uses 67.0. As for my Repeater channel, I use a DPL. Also, what difference does it make to you or anyone else what PL or DPL is used. You can either program it accordingly or not use it at all.
kayn1n32008
Sector 001
It was a rhetorical question.
It doesn't. It's about your word salad of words, that didn't even address the OP's ACTUAL question. It should have been a single sentence like:
The NAC equivalent to ASTRO carrier squelch is $F7E.
Simple, to the point.
