Motorola RDU4100 Channels Not Working
ylink
California
Hi, Im new to the forum but Im hoping someone can help. We are using RDU4100 radios. I have one unit that when you turn the channel knob, it doesnt announce the correct channel or at all for some knob turns. Its skipping channels and doesnt even go in order.
Knob on 1 - Announces Channel 1 - Correct
Knob on 2 - Announces Channel 2 - Correct
Knob on 3 - No Announcement, nothing happens - this is my main problem and I need for it to go to Channel 3
Knob on 4 - Announces Channel 1 - should be channel 4
Knob on 5 - Announces Channel 8 - should be channel 5
Knob on 6 - Announces Channel 7 - should be channel 6
Knob on 7 - No Announcement, nothing happens, should be channel 7
Knob on 8 - Announces Channel 8 - Correct
Knob on 9 - Announces Channel 9 - Correct
I have the CPS cable and have been trying to ticket around in the CPS software, but I dont see anything out of place. I took a known working radio and checked the settings and they appear to be the same for this non-working radio. Does anyone have any suggestions on how I can get the channels aligned properly and getting on each channel?
AM909
Radio/computer geek
SoCal
Did you actually re-program in the bad radio using the codeplug from the known working one? Probably bad channel switch/encoder if it behaves differently than another radio when both have the same program. The part may or may not be available – I don't see a manual.
ylink
California
Im fairly new to diagnosing and fixing radios. I have not tried to reprogram it, not sure what a codeplug is to be honest. I spoke with Motorola support and they said its most likely a defective board. Im assuming the channel switch encoder is soldered onto the board? Im not looking to do any heavy work on this, thought maybe I could do something with programming to fix it. Anything I should try first before calling it done?
Asunakiyori
Lurker
Hiding in a Shed somewhere
codeplug is the thing you're sending to the radio as "programming"
ylink
California
Do you think sending a codeplug will help fix this issue or does it sound hardware related? Im just trying to see if Im calling it quits on this radio or anything I can do to save it.
AM909
Radio/computer geek
SoCal
Read the problem radio with CPS. Save it (the "codeplug") just in case.
Now, attach a working radio (has to be the same identical model number) to CPS and read it. Then, attach the problem radio and click "Clone" to write that working codeplug to it. That's it. If it's still broken, it's a hardware problem that you won't fix.
ylink
California
I need to attach both working and problem radio at the same time? I have only 1 CPS cable, but not sure if it works for cloning. And where in CPS do I find the clone option?
AM909
Radio/computer geek
SoCal
Sorry – I was picturing the wrong CPS.
Attach the good radio. "Read radio". Detach the good radio. Attach the bad radio. "Write to radio".
ylink
California
When I have the good radio and read radio, dont I need to save the profile to load back to bad radio? What would I write to bad radio ?
AM909
Radio/computer geek
SoCal
"Write to radio" writes whatever codeplug is currently opened, whether you opened a saved file, or read it from a radio and then saved it or not.
(They appear to use "profile" in this particular CPS to mean codeplug or the file in which a codeplug is stored, interchangeably.)
ylink
California
Ok, So I tried that, but unfortunately it didnt change anything. It appears to be a hardware issue. I think I have to call this radio non-functioning at this point.
