Motorola RM Device Programmer instalation error.
Sparc
Hello, i have problem installing Motorola RM Device Programmer.
When installation is in status: Starting services - i've got "error 1920. Service Motorola RM Device Programmer (MotorolaRMDeviceProgrammer) failet to start. Verify that you have sufficient privileges to start system services". I tried start this service manually (services.msc) and nothing helps (i tried change login to admin account).
Also tried install different versions of net frameworks, and install all new updates on my Windows 10.
Anyone know how to solve this problem?
Project25_MASTR
Millennial Graying OBT Guy
Texas
When you run the installer, did UAC pop up and notify you of required admin permissions? Sounds like it isn't launching with admin privileges.
sjaltavilla
Vermont
Check out this article if you have a CustomerHub account:
If you can't access it, here is the solution:
"The resolution for "Error 1920: Service Motorola DM Device Programmer failed to start" errors is to remove C:\ProgramData\Motorola\CommonCPS\RM Job Processor\user.config or the whole C:\ProgramData\Motorola\CommonCPS folder for a cleaner installation"
I have personally had luck with the latter.
Sparc
Thank You! it helps when a removed CommonCPS folder :)
