Motorola Select-5 decoding. Help required
mikegilbert
MHz so good
Los Angeles
Unfortunately your link requires access to listen.
You should be able to attach the file directly in the forum.
Ubbe
Stockholm, Sweden
It sounds like EEA that uses 40ms tone lengths and it's more than 5 tones, so probably adds it's own ID at the end.
/Ubbe
Frasso
/Ubbe
I have tried all available standards, including EEA without success.
Maybe some settings on sorcerer are wrong or the signal is not strong enough
I know that is an ambulance dispatch (here in italy) and I know that those are the status the ambulances send.
I'm expecting to see some text like "N. of ambulance on scene/back to base"
Ubbe
Stockholm, Sweden
Look in its FFT spectrum display if you see the signal there. I downloaded the program and only see my own windows sounds appearing but not when playing from a file. It seems to only decode live audio. Maybe there's a way to redirect the audio from the file in some way but I have so far no success with that.
/Ubbe
Frasso
/Ubbe
For redirect the audo from the file I used VB cable.
On Sorcerer go on File > options > sound card optitions.
Frasso
This is what I see on the waterfall
kf8yk
I think this is Hexadecimal Sequential Code (HSC) format.
HSC uses tone frequencies & timing similar to EEA/CCIR 5 tone but allows sequences much longer than the common 5/6 tone format.
Here's an application note with the details: HSC Signaling
This format has been around a while but was not a popular option in North America. The old ACC RC-850 repeater controller even supported it: RC-850 HSC
Using the HSC format on your first audio file both tone bursts decode as: 0295111901, all tones were EEA format & 40 ms timing.
Frasso
That's interesting...
Is it possible that what you have decoded "0295111901" on the radio (a motorola gm family) is shown as text?
The first brust should be from the ambulance the second from the dispatch
Like "back to base" "copy"
kf8yk
Unlikely it's text, in the HSC format a 'B' tone would precede a block of text & there's no B tones (930 Hz) in your recordings.
Usually status messages are not meant to be plain text readable, typically one or more of the digits encodes the status (1=enroute, 2=on scene, etc.) and the remainder are the unit ID. Log all the messages & look for a pattern.
If you look at the Euro GM300 sales guide on page 45 it shows how this radio can be programmed use 1 to 8 digits for unit ID and 1 to 3 digits for status codes.
Frasso
Seems like they're using the 5-tone as status messages.
Yes it should be like that.
I tried deciphering the numbers that way.
I found a document where these states are specified. However, it only indicates 2 buttons for a total of 4 sendable states...
It's unfortunate that the content is only numeric, it doesn't make identifying the radio system any easier
