XPR Motorola XPR 4350 Repeater home build
Priv8eye
Florida
Hello Everyone, I have a question in regards to a Motorola XPR 4350.. is it possible to pair up 2 of them via 26 rear pins to make a homemade repeater like the Motorolas CDM or GSM radios? been looking online but cant find any information. Any help will be appreciated. Thanks and stay safe.
ramal121
Lots and lots of watts
Calif Whine Country
Is it possible? Well yes. You will not be making a true digital repeater with those. Instead you'll be "patching" two radios together via the audio "hole". Not as nice as a true repeater because you'll be double vocoding the audio but it does work to a point. All using the accessory connector on the back of the radios. This is all assuming you will be using DMR for this.
Priv8eye
Florida
Thanks Ramal121 for answering my question… with all honesty I just wanted to build an analog repeater like the home made repeater used with the cdm1250 they have been awesome and the TX and RX repeater cables are for sale all over the internet but nothing to build a XPR but thanks to you I know now it’s possible just need to figured out what pin goes with what pin and put it all together. I really appreciate your help thanks.🙏
Priv8eye
Florida
XPR can be used for an analog repeater. Built a few. Just order the acessory kit and build your cable.
Hello, thanks for the help, could you tell me where can I buy the necessary equipment to make a repeater? been searching all over the net and cant find anything to pair the xpr 4350 together any help its appreciated.
jeepsandradios
East of the Mississippi
You need 2 of these kits and some wire. Read the manual and you will find what needs programmed and what pins to use. You dont need anything more than that for a basic repeater. If want bells and whistles then you need a controller.
Priv8eye
Florida
Thats awesome thank you so much..ordering now really appreciated it. HAve a blessed week and stay safe.
Jeepsandradios, could you tell me what controller you recommend for the 2 xpr 4350 to make into a repeater? cant figure out the pins and a might be easier to just buy a controller... Thanks for your help.
Im still trying to figure out the xpr 4350 and how to pin the RX and TX together.. do you by any chance know someone that I could paid for them to make me some cable?
