XPR Motorola XPR 6580: clean codeplug needed
IK7VXC
Hi everybody. I just bought off Ebay a second hand Motorola XPR 6580, and once I received it I found out the seller had conveniently omitted to state that the current codeplug was password protected. I know I can return it, but, if anyone is so kind as to share a clean codeplug I'd be much happier.
Thank you
and 73 de IK7VXC
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Thank you
and 73 de IK7VXC
Pretty sure that's not how it works.
IK7VXC
Thanks for your prompt reply Kevin. Please enlighten me ... If there is nothing I can do I'll return the device.
K2NEC
5F6
Cant write a clean codeplug if the radio is write protected.
K9KLC
Southwest, IL
I won't say there's nothing you can do but returning it and starting fresh with one that's not password protected would be the best avenue I think for you if that's an option. XPR 6580's are pretty plentiful and cheap at least here in the US so I'd find another one.
IK7VXC
Thank you. I bought it because it was cheap. If I had known it was password protected I wouldn't have bought it. Damn ... I'll return the radio if I don't find any other solution.
K9KLC
Southwest, IL
I'm guessing by your username you're in Italy?
I'm also guessing you know this is a 800/900 MHz radio?
IK7VXC
That's correct. Which makes things a little more complicated.
N4KVE
PALM BEACH, FLORIDA
There’s a big difference between a radio that’s locked, & one that’s write protected. I’ve purchased several that were locked, & simply did a restore which reverts the radio to the day it was built, totally blank.
IK7VXC
To restore the radio I need the packages which at the moment are missing in my CPS. I should probably ask MotorolaSolutions for them. Sorry, I'm new to the Motorola world, so I'm learning the hard way.
K2NEC
5F6
A restore and a codeplug write are not the same thing. OP asked about a blank codeplug to write into the radio, which wont work if theres a write password.
If he wants to restore, he will need the matching firmware package.
IK7VXC
Sorry, my bad. Like I said I'm learning the hard way. Yes, I need a matching firmware package. I don't know if this is freely available or needs to be bought.
K2NEC
5F6
Well, what firmware version is in it?
IK7VXC
Currently it's installed firmware version: R01.12.17. But - correct me if I'm wrong - I believe I also need the XPR6000 Device Package (NA) and a Recovery Database (?)
What I know is the CPS does not have the device package and can't perfom the update.
Any help here is VERY MUCH appreciated.
Michele
K2NEC
5F6
You just need to install the firmware package and then do a recovery with CPS.
K9KLC
Southwest, IL
Just find 1.12.17 and recover the radio then. that's the last commercially released (that was common) for that radio. I've updated many of the 6000 series radios with that. It's on the Motorola site under legacy stuff.
