Hi all i just purchased this repeater xpr8400. The person i got it from bought it at auction and said he couldnt program it ofcourse no further info
When i power it up the leds dont cycle like they usually do just the solid green power light comes on and stays on as well as the fan. No other lights ever come on.
I snooped around a little bit checking all the cable connections they are good. Next i checked power out from the supply good.
I checked the two boards led board in front and control board the leds worked when i jumped them.
I checked every pin to every connector they all seem to have power going through where they should even both radios, so i would guess they are not completely fried. Also when i plug an ethernet cable in the rear jack the two little lights on it do not come on. The pins have some mv current going through them.
I tried a bunch of cps that i could get from mol most of them are only a few years old
the repeater was made in 2010 version on the tx radio label is R01.08.10 i tried depot tool and rdac but not lab tool as i couldnt find one all with the same result cant read or write as if nothings connected.
Im ready to use this thing as a boat anchor is there a hidden reset or something im missing?? im pulling my hair out over here
thank you all in advance..
