Motorola XTS3000 programming issue
Hello Motorola group
Having a problem programming my Motorola XTS3000 UHF Model 2 403-470 Mhz
I'm can not add NUSI to my display. I have use version R05.03.00 AND R05.02.00 Cps
When I choose NUSI in any position on the display it WILL NOT show up. Everything else programs fine. ANY IDEAS ??
Ron.
jmfirefighter
Raymond, NH
Is it in scan mode when you're trying to see if it's there? Not sure if it's dependent on it being in scan for the nuisance soft menu option to display. Been a bit since I've played with an XTS3K.
yes I have scan mode on I use the bottom side button for scan on/off I just think it's the code plug in the radio
I'm Still working on this issue I sent up the the codeplug 2 times to this forum but it's wont go ??
I'll try and reload the original CP and start all over programming the radio It will take sometime but I'll get it working right
