Motorola XTS5000 VHF Quick Call II
radiomansc
I have a motorola XTS5000 VHF quick call II that has quick call signalling on 3 channels. I want to scan these three channels with the channel closed (waiting on valid QC II tone set) but the channel is open when it scans but closed on the channel when not on scan. How can I change it to closed when scanning the QC II enabled channels?
SD70MAC
NC
You SHOULD be able to set the Signaling Squelch to "AND" but I have not gotten my XTS5000 VHF to do this. I have been programming the HT/CDM for years and they all work fine,but not the XTS. I cannot get it to let me use more than one QC tone set,it always reverts back to #1 ?
Josh
Auburn Hills, Michigan
SD70MAC:
Your FPP XTS5000 will only allow you to select from one signaling system for the first 240-ish channels, these are your FPP channels. Outside of that you can go wild on signaling systems. This was never an issue on older FPP XTS5000 radios, the ones with Q53 but not Q52 and host/dsp9 etc.What you would need to do is go beyond channel 240 and add new personalities. These will allow what you want.
As for the scanning thing, what is the host/dsp of your radio? It may be helpful.
SD70MAC
NC
xts
Thanks, good info ! It will only let me add to 254ch but I don't need that many just was going to add the ones I don't change past the FPP. Thats ok though .
DSP; 12.00.01
HOST; 12.00.11
Mine has Q52 & Q53
Josh
past the first 254 FPP modes, it should allow you to do whatever you want beyond that. My radio has several zones of unprogrammed FPP channels to get to the non-FPP zones so I could add different features and signaling systems.
SD70MAC
NC
Qc2
Josh,
I did find that the QC was resetting in 5 sec and have fixed that issue. It was decoding the QC I just did not see it because it was so fast to reset. I am going to work on adding channels past the FPP on Monday & Tuesday ,thats the next days I'm off because I work the next 3 days.
