Motorola xts5000
Seanm214
Kings Park, NY
I'm looking to buy a Motorola xts5000 to scan trunked p25 police and fire and also for conventional use. Am I better off buying a model I or model iii radio. Does the model I radio decode nbc ID's like the model 3 does and have the same digital capability as the model iii radio does. Also if you have programming software for the radio then what is the point of having the full display keypad in the front of the radio for the model ii and model iii radios?
Thanks.
Project25_MASTR
TX-COMU
Texas
To answer things simply...a Model 1 is a non-display radio (so while it will decode IDs (it won't alias them) it has no way of displaying those things. There is also no way to access more than 48 channels/talk groups in the radio.To the best of my knowledge, a XTS5000 was never offered in a Model 1.5 (with display). As far as capabilities go...as long as the flash code supports the features...then yes they are just as capable as they are the exact same board with the Model 1 simply not having a display and keypad plugged into the board.
Main advantage to the Model 3 over the Model 2...the keypad allows you to directly dial numbers for signalling (want to page an ID or send a manual non-preprogrammed DTMF command). That's the real advantage to the model 3 (I don't own any Model 3's personally because I typically don't have that necessity outside of mobile applications).
W
W4ZMJ
Guest
Model 3 probably not necessary model 2 will work just fine. If you was considering a model 1 xts5000 I just get an XTS 1500 1.5 which just has a display with no keypad. Or 2500 1.5
Sent from my LG-H343 using Tapatalk
Seanm214
Kings Park, NY
Thank you, I will probably buy a model ii off of eBay and buy software to program it.
Seanm214
Kings Park, NY
Thank you, I will probably but a model ii off of eBay and buy software to program it.
