Mototrbo CPS 2 Monitor
joncleve
Western NC
Hi. I have my XPR7550e programmed with CPS 2.153.0, firmware R2.10.10.0001. It's working great but I cannot get the monitor function to open the squelch on analog channels. I do have monitor type under the general settings set to open squelch. But assigning monitor to any of the side buttons does not work. Any suggestions?
KG4INW
Midlothian, VA
Is your TX Admit Criteria set to "Channel Free" by chance? That would cause that behavior. If so, try changing it to "Always" instead.
K9KLC
Southwest, IL
This tripped me up in the beginning...Also does "silent" even work? Why is that in there if you happen to know?
joncleve
Western NC
That was it, changing TX Admit Criteria set to "Channel Free", working now. KG4INW thank you very much.
KG4INW
Midlothian, VA
It should just eliminate the sub-audible without also disabling the squelch completely. Probably another way to satisfy FCC regulations without having to listen to the white noise.
K9KLC
Southwest, IL
Ok, thank you. Basically then if it's an CSQ situation it does nothing I guess. Again, thanks.
