MotoTrbo Enhanced Privacy Decode
I have a MotoTrbo XPR7550. I use to monitor a county close by who uses a Trbo digital system but they recently changed their encryption codes. Everything else stayed the same, so I can still see them key up on my screen and see who is talking but just can't hear anything. Is there anyway to figure out what the new encryption codes are or somehow decode the transmission?
JRayfield
Springfield, MO
Why don't you ask them for the code?
Keep in mind (in case you're not aware of it), that unless that agency specifically grants you permission to monitor their encrypted transmissions, then doing so is a violation of U.S. Federal Privacy laws. If you do not have permission, and someone there finds out that you are monitoring them (assuming that you figure out the encryption key again), and they complain to the FCC, then you could be in a LOT of trouble.
John Rayfield, Jr.
That's not an option at this time. Thanks for the info. Back to my original questions.....
MTS2000des
5B2_BEE00 Czar
I'm sure the O/p means color code not encryption code as decrypting encrypted radio traffic without authorization is unlawful and a taboo subject.
To get the color code he/she could use a program like DMR Decode with an SDR to obtain the desired system data/
KG4INW
Midlothian, VA
DMR Decode won't yield privacy information. It sounds like you already have the frequency, color code, time slot, etc. You won't get that help here.
Ok. Yes. Where could I find the DMR DECODE WITH SDR program ?
What part don't you get that hacking encryption codes for monitoring is illegal. If the sys admin won't give them to you, tough luck. If you keep asking expect a visit and if convicted don't bend over to get the soap. There is a reason the talkgroups are encrypted.
Or all of this is just a troll...
So Far Away....
While we're on the subject,I need the ENC key to a local PD's secure P25 channel...Oh,,And Ill take the keys to the medley of alphabet agencies too...You can just post them here,,No need to mail them to me...
Haaa...I needed a good chuckle!
S
SARCommCoord
Guest
I heard that if you send your radio off to the DPRK (Democratic Peoples Republic of Korea), they will program all the encryption keys you will ever need. Of course, the cost for this is you must sell your soul to Kim Jong, but it seems like you would do anything for these codes.
