MOTOTRBO High Pitch Noise
jwpd416
We have about 30 MOTOTRBO radios, combination of 7550, 7550 E and 6550. Randomly a random radio will produce a very loud and very high pitched tone for a few seconds. Is anyone else having this problem or know a solution?
Thank you
WB0VHB
Mt. Union, Iowa
I have a 6550 doing the same thing. It has the latest firmware and otherwise works fine. Looking for an explanation too.
jtech48
OVB
Can you provide a bit more detail as to what type of system the radios are working off of (Cap+, Con+, etc) or if conventional?
JRayfield
Springfield, MO
Does it produce it on transmt or receive?
John Rayfield, Jr.
Thank you
jwpd416
John Rayfield, Jr.
Neither, it does it randomly. The last time it happened with mine, it was sitting on my desk and with out anything going on it happened. I wish I could provide more information but it is so random I have no idea.
mw1coe
Gas, KS
I heard that Certain batteries cause this issue..
Try covering the center battery terminal..
jwpd416
No it is not a ticking noise, it is a very high pitched tone for only a moment.
jwpd416
John Rayfield, Jr.
So I have several radios on today and have been paying closer attention. As of today I have 2-XPR 6550 that have made that sound twice today. Both at the end of a transmission.
masstech
Which radios were transmitting? Maybe they were the 7550e's, the newest ones? What does firmware look like on all the radios? The thinking here is the 7550e firmware might be doing audio processing that the gen 1 radios are receiving as that sound.
jwpd416
All the firmware has been checked and updated in the last two weeks. I believe one of the transmissions came from dispatch and the other a car radio. I will have to pay closer attention next time.
ae1c
Does the tone sound like a CO alarm? Did it happen after upgrade to latest fw on 6550? Mine did. It absolutely started happening right after the update to current fw. I did two radios. One is still ok but one is useless now due to the ear piercing scream. It can work ok for a month then happen 2 or 3 times in a row. Doesn’t matter if it’s on analog or digital channel. Doesn’t have to be actively receiving anything. It HAS to be caused by the last fw upgrade. Volume control does not affect level of tone. Have to power cycle radio to stop tone. All else works fine!
com501
There is a fix for this specifically for the 6550. Have MOL send you S01.17.08_130203 for the XPR6550. This is a known condition.
Anderegg
Enter text in this field
San Diego
I've got an XPR4550 that emits full blast feedback squeal (how is that even possible!?) from the speaker at times when I key the mic...it can literally burst an eardrum.
Paul
GTR8000
NY/NJ Database Guy
BEE00
Same issue here with my 6550, it's awful.
ae1c, what method did you use to request the firmware through MOL?
N4KVE
PALM BEACH, FLORIDA
Happened to my 6550 once. Turning the radio off did nothing, so I removed the battery. That was a year ago, & it’s never happened again.
