I'll ask elsewhere. Sorry to bother you.
DMR uses Time Division Multiple Access(TDMA), to share a single 12.5kHz radio channel(pair if using a repeater). In the case of DMR a single RF channel can have 2 unique, simultaneous, voice paths.
Color Code:
Works similar to PL or DPL. It is a channel access method. If the transmitted color-coded is different than what the repeater is programmed with, it won't respond.
Time Slots:
DMR has 2 time slots. Time Slot 1(TS1) and Time Slot 2(TS2). These are the 2 audio paths.
When 2 separate users are transmitting, one programmed for TS1 and the other for TS2, each radio is keying and unkeying very rapidly, approximately every 30ms. The radio programmed for TS1, the first 30ms, then it unless for 30ms, while it is unkeyed, the radio programmed for TS2 keys up for 30ms. During each 30ms cycle each radio transmits enough data to bridge the 30ms its not transmitting. To each user, there is no interruption in audio on to the radios receiving.
The repeater provides the timing reference to define TS1 and TS2 to the user radios.
If the repeater is in standby(not transmitting), when a radio keys up, it sends a series of 'wake up' packets. This is so the repeater can key up, establish time slot sync, and tell the radio when to start transmitting on the slit it is requesting. The repeater transmits a continuous carrier, regardless if it's one or two timeslots in use. Only the user radios rapidly key and unkey.
TalkGroup or GroupCall:
Think of these like virtual channels. This allows mtiple users to utilize the repeater, with out having to hear the other users. For conventional repeater use a Talkgroup can be any number from 1 to 16777215.
The exception for this is Motorola Capacity Plus trunking, Talk Group numbers are limited to 1-254. 255 is reserved for All Call
Contacts:
Every DMR radio needs a unique numerical ID, a Radio ID(RID). It can be any number from 1 to 16776415
. The contact list allows you to alias the RID with a name.
The exception for this is in Motorola Capacity Plus trunking, RID can only be 1 to 65535.
Ham radio uses conventional DMR. Repeaters are linked via the internet to form huge networks. Some can also use 'hot spots'.
Hams need to be assigned an RID through radioid.net This is held in a database that can be down loaded and dumped into many DMR radios, so you don't have to build your own contact list.
