MOTOTRBO Radio Management Error 20010
Firebuff880
Boynton Beach, FL
Depends on what you are trying to do --
You must read the radio first to establish the Model Version Option (MVO) data in RM.
But if you have a number of identical radios to program you can;
  • Enter all the Serial Numbers / Radios from a CSV.
  • Read the first one.
  • Select All the others and Copy the MVO data from the First one.
  • Assign the Configuration, and the Radio Id & Alias if you did not do so in the CSV.
  • Schedule all the write jobs.
Sparc
The radios were already read and programmed many times, but now it doesn't want to wait for programming like before to connect the radio with a cable, it just shows "not done".
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Schedule a read job, then write it with RM. See if that clears it.
Have you upgraded the RM or moved/restored the database?
TT
Sparc
TT
As I wrote in the first post, it helps, but I would have to do it with each radio in the base and I have a lot of them.
I didn't do anything with the database.
Are you running an all-in-one setup or distributed setup? Any firewall changes?
All in one, no changes in firewall.
Sparc
I've got this log in: CommonCPS/RMJobServer/Log
Code:
<Exception>: System.IO.DirectoryNotFoundException
<Message>: Nastąpiła próba uzyskania dostępu do ścieżki, której nie ma na dysku. (An attempt was made to access a source that is not present on disk.)
<Source>: System.Data
<StackTrace>:    w System.Data.SqlTypes.SqlFileStream.OpenSqlFileStream(String path, Byte[] transactionContext, FileAccess access, FileOptions options, Int64 allocationSize)
   w System.Data.SqlTypes.SqlFileStream..ctor(String path, Byte[] transactionContext, FileAccess access, FileOptions options, Int64 allocationSize)
   w Motorola.CommonCPS.Server.Providers.FileStreamProvider.FileStreamProvider.GetFile(String url, Int64 offset, Int32 bufferLen, Guid guid, String agencyId)
   w Motorola.CommonCPS.Server.Repository.RepoWithFilesAccess`1.GetFileContentEnhancement(Guid filGuid, Int64 offset, Int32 bufferLen)
   w Motorola.CommonCPS.Server.DataAccess.DataAccess.GetFileContentEnhancement(RMFile file, Int64 offset, Int32 bufferLen)
   w Motorola.CommonCPS.Server.JobService.JobService.GetFileContentEnhancement(RMFile file, Int64 offset, Int32 bufferLen)
   w System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs)
   w System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg)
