Mototrbo repeater feature
J
jerryray
Guest
Does anyone know if I could create a reject list?
I am trying to understand if I can make this system secure from the NY jammers. They have a radio guy working with them.
So we need to be smarter than them.
I was told I could order with RAS and remote control boards.
I was also told RAS is a lsit I must build and it only works with Motorola radios.
We would like to allow the inexpensive CS700 access to the system.
Any guidance would be appreciated
TIA
PS repeater not purchased yet, need to know all the options we may need to order.
rr60
Yes to exclude list
Suggest you search for Mototrbo system planner PDF.
You can exclude a RID or a group of ID's or make a group to be included only.
No RAS option needed,but nice to have along with this feature.
You will need to go the site to program the repeater.
If you are to exclude an ID you need to know it, of course one can always change the RID if one put 2+2 together.
J
jerryray
Guest
OK, I did dl the pdf and scan through the features, but did not find the exclude section.
Where in the document did you find this?
This sound like it could be the answer, guess if I had the remote package with the MTR, I could program the repeater from the GUI to change this?
com501
Remote repeater programming is a software entitlement for your REGISTERED software, good for one computer. I would not suggest uploading firmware upgrades that way, I think the software won't let you.
ID Range Restrictions are not part of the codeplug until Restricted Access to System (RAS) is purchased for each repeater in your system and entitled/registered. If a single repeater, only one EID needs to be purchased.
HKVN4047 IP Repeater Programming and Upgrade License $250.00
HKVN4177 Restricted Access To System Security $250.00
