Mountguys - Pro-96?
SAR923
Yes, I have on for my Pro96. It mounts to the floor using a seat bolt and it is very heavy duty, as the ad states. You can angle the mount in whatever direction gives you the best view of the scanner. Mine is in a Suzuki Grand Vitara and I imagine it would work about the same in your Pathfinder. For less than $20.00, it hardly pays to make your own.
cycle687
I've also nocited that you probably have to take the belt clip off for mounting, as well as possibly no room for the A/C adapter plug? I'll do some thinking, maybe I could come up with something under $20 cost.
SAR923
No, you don't have to take the belt clip off and there's plenty of room for the power plug. The jaws open to about 5 inches and have soft foam rubber linings so they conform to the power plug. The jaws are also deep enough to accommodate the belt clip. You can homebrew one if you want but I suggest you give the commercial version a try first. You can always return it if it doesn't work for you.
cycle687
Thanks, that's good info! Could you possibly post a pic of your setup with different views than the mount guys site has?
trooperdude
SFO Bay Area and Las Vegas NV
cycle687 said:
Anyone have experience with this mount from Mount Guys?
http://www.mountguys.com/product_p/cm625-scanner.htm
More specifically in a Nissan Pathfinder? What about home-brew mounts, are they even worth making?
I tried one in my 2006 Pathfinder in a cup-holder mount.
It was always getting in the way of the DC plug.
The holding power is pretty weak too, and the cheap plastic didn't last long
under routine abuse and a summer in the hot sun.
YMMV.
Tim-in-TX
Pearland TX
Looks like the one made by Arkon that I got off of Ebay. It fit my Pro96 fine, and the flexible arm is very strong, so you won't have to worry about any "sag" due to the weight of the scanner.
