TRX-2: Move scan lists
rickr855
Paonia, CO
I have several years experience with PSR600 scanners. Bought a new TRX-2 a few weeks ago. Programmed by zip code ok. Now i want to 'fix' the errors and use my own scan lists. How do I move the items in Law Dispatch to Scanlist 001?
PrivatelyJeff
Has more money than sense
Kings County, CA
go to the conventional tab in EZSCAN, select all the objects you want to edit, then click one of the objects under the column “scanlist” and then select where you want them to go and deselect where you don’t want them.
rickr855
Paonia, CO
oh wow, didnt know scanlists was on there until I expanded to full screen. that worked for conventional and talk groups.
Thanks Jeff !
PrivatelyJeff
Kings County, CA
Thanks Jeff !
no problem. I sometimes have to shift tons of stuff around when I’m reorganizing the list.
