BCD436HP/BCD536HP: moved freqencys
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
Never had an issue with a 436HP, two 536HPs or an SDS100. Ensure once you get the desired programming written to the scanner, you READ FROM SCANNER, make any necessary changes in Sentinel then WRITE TO SCANNER.
bob550
Albany County, NY
More detailed specifics about what exactly happened would be helpful. Had you just performed a database update before noting this behavior? Normally, FL's and the frequencies contained within are not affected by database changes unless you initiate the change.
slayer7303
McCamey Texas
its not doing it when i update the database... it seems to be random events. I can go into sentinal and find channels moved from one fl to another or have two or three of the same channels on diferent lists.... the ones it seems to be hapening with most are my texas dps freqs and my GATRRS list
jonwienke
More Info Coming Soon!
VA
Sounds like time for a new card.
slayer7303
McCamey Texas
i would agree if it was my scanner doing the changes but its only on my computer that it happens..... i use the sintenal for my bcd 436 and a SDS200... coukd it have something to do with my using the sdr program for my TRX-2?
kruser
Well Known Member
W St Louis Cnty, MO
As cheap as SD cards are, I'd take Jon W's advice and get a couple more cards.
Bad cards have been known to cause some very odd issues.
As to the question about the TRX-2, that should not have anything to do with your Sentinel problem.
What is this "sdr program" you mentioned for the TRX-2? I've never heard of such a program for a Whistler model like the TRX models. They use a version of what used to be called EZ-Scan in the GRE days. Whistler's programming software is named based on the scanners model for the programming software name. Their TRX-2 software is called "Whistler TRX-2 Base/Mobile Digital Scanner Programming System".
It would not change anything in Sentinel either.
slayer7303
McCamey Texas
It is the ez-scan that I use for the trx 2... a bad card would cause this issue on my laptop even if I'm not connected to the scanner?
bob550
Albany County, NY
Without a direct connection between the scanner and computer, the state of the SD card would have no effect on the computer. If your troubles are only occurring in Sentinel, and you have made no changes within Sentinel, and you have not connected and downloaded from your scanner, then it's possible that your Sentinel file in your computer has been corrupted somehow. You can download your 436 into a fresh new Sentinel file and see if the original problem reoccurs.
