MT-1000 question
Markscan
New Jersey
I have an old Mt-1000. It has 8 channels, and works pretty good. it has some old security fequencies in the UHF band. How can I tell exactly what the coverage is?
Model # is H44GCU7180AN
Any help would be greatly appreciated.
Josh
Auburn Hills, Michigan
Unless you know what frequencies are programmed in it already, you will have to dismantle the unit and get info from the RF board in order to know what UHF split it is.
-Josh
chrismol1
Could be 438-470MHz but not sure. If you knew just one frequency it would help
Markscan
New Jersey
I know one channel is programmed for 464.325. I believe the others are all fairly close to that. I'll have to check it out a little further.
wa8lgm
North Olmsted, Ohio 44070
look at the inside back of the radio and get the model number. Call a Motorola tech and he/she will be glad to give you the frequency range of the radio. It is actually THAT simple.
Josh
It's actually not that simple. Not with the HT600/MT1000 radios.
The model number would decode as "UHF" 403-520 or whatever the max split of the entire radio series in UHF was. The radio is actually a sub-split of this.
from HT600/MT1000
"HT600 Bandsplits
Again, there are only two ways to determine the bandsplit in the radio. You can read the radio with the RSS, or open the radio and look at the split printed on the VCO board.
The available bandsplits for these radios is as follows:
VHF UHF
136-151MHz 403-433MHz
146-152MHz 438-470MHz
157-174MHz 470-500MHz
488-520MHz"
And there it is.
gatekeep
FAIL 01/93
New York, NY
If he has freq's similar to 464.325mhz, I'm pretty sure that the freq split of the radio is UHF-Lo2 (438-470). Other than that guess work, opening up the radio and looking at the RF board or reading the radio with RSS will determine the bandsplit.
Josh
If it is a 464 radio, then the bandsplit is 438-470. They don't really go "out of band" well, from what I've read which has got to be a plus on the selectivity standpoint.
jwb8734
If you were to call Motorola and give them the Model number and Serial number they can look up the record without taking appart the radio. The other option is goto a local Motorola dealer and have them connect the programmer to it and they can tell you what is programmed in the radio.
chrismol1
If one frequency is around 464 then the band split is 438-470MHz
