MTA PD frequencies
The MTA PD replaced the LIRR PD and the Metro North PD as one combined department as of Jan. 1, 1998. Each of those agencies kept their respective frequencies they were using at that time. The operating railroads continued to exist as they were. The frequencies used were licensed under those railroads at that time and through agreements with those railroads the new MTA PD has continued to use them. The system is quite varied from location to location. In the Eastern Region which is comprised of Penn. Station and points east there are both repeater and simplex systems. In the northern region there is on a simplex system. Both systems are supplemented with NEXTEL which is used quite a bit. A new 700-800 system is on the horizon which will be used by not only the PD’s but the railroads that the PD’s are assigned to protect. As SCANdal correctly pointed out the bases do not transmit a PL, only the field units do. A small in-house repeater system is used inside Penn station so don’t expect to hear a big power house signal. NJ TPD has been listed as Metro North RR has a “West of Hudson” line and it does go through parts of NJ. Amtrak PD is listed due to the fact they have a PD unit within Penn Station. BTW Johnny if you are located in Ct. you are in District 8 which is in the North Region.
I’ve listed the frequency use plan for the field units below :
NYS MTA PD Frequency Use - Mobile Units
161.2200 / 161.2200 PL 123.0 / CSQ North Region Dispatch F-1
160.5600 / 160.5600 PL 123.0 / CSQ North Region F-2 Car – Car
161.4900 / 160.3200 PL 151.4 / 114.8 Penn Station Repeater
160.4550 / 160.4550 PL 151.4 / CSQ East Region Dispatch “E-1”
160.6050 / 160.6050 PL 151.4 / CSQ East Region Car- Car “E-2”
161.5200 / 160.8300 PL 179.9 / CSQ NJ TPD 1
160.8300 / 160.8300 PL 123.0 / CSQ NJ TPD 2
160.3650 / 161.2950 PL 131.8 / 131.8 Amtrak PD Penn Station
160.3650 / 161.2950 PL 156.7 / 156.7 Amtrak PD SNYD
161.2050 / 161.2050 PL CSQ / CSQ Amtrak Car – Car
Good scanning,
Spec
