mts 2000 CPS 2.02
dss261263
UK
Hi Folks newbie question for you all, I am loking for a site or notes on what all the various programming options do with this software, mts 2000 for a f12/22 handheld 15 channels , I open the softare up ans am presented by common setting memory, using cps 2
DTMF
Scan
5Tone
When I enter into each of these section there are multiple choices, apart from the frequency 449.7000 etc what does the rest of these setting do all ove the package, I have printed of the help and am struggling to get it figured out and worked together, and dirextons would be great or any old notes from when someone started.
Icom F12/22 16 channel radio
Vertex vx 160 standard vx-351
Motorola mts 2000
I noticed that wach makes calls things differently, both the ICOM and Vertx will put out an emergancy call or tone at the push of a button but the mts2000 will not top displays and full key display
thanks in advance David
davidgcet
i was lost before the 1st line ended.
gary123
you are looking at the varios signalling types the radio is capable of. but remember just because the type is in the menu dosnt mean that the radio will support it.
MTS2000des
5B2_BEE00 Czar
my head hurt reading the OP's post.
the documentation you get from Motorola when you get your CPS from them includes a CPS user guide. that's a good starting point. they also give classes (and charge accordingly) on using their CPS for various radios.
what specifically are you asking?
dss261263
UK
HI
Thanks for the speedy replys, if radios are used in very noisy places, night clubs etc, verbal communication is not ideal to say the least, Icom F22 and vertex vx160 have the facility to press say the top side button and this will send a coded tone out, can the MTS 2000 do the same. The MTS 2000 are back to back on 449. channels. Apologise for the vague question after searching for some time it becomes a real issue, Can I program an MTS 2000 not trunked to send out a tone that is audible on other radios tuned to the same frequency, and as the Vertex, can I alter the type of tone or bleeps it sends, say if the radio upstairs if keyed my radio will recieve say 5 bleeps, down stairs radio keyed say 2 bleeps
This -> coiled ear bud headset w/mic
gary123
aside from the headset which is a great idea for your niosy enviorment, you could select signalling (MDC) yjis will give a tone to the sender along with a data burst to the reciever. Another advantage is if you have a display capable unit you can see who transmitted.
BTW 449 is ham radio I wouldnt recommend using the radios on ham freq for commercial use. Hams are notorious on tracking down such users and complicating thier lives. I recommend if your commercial use commercial frequencies (licenced of corse)
mm
oregon
You unlock this door with the key of imagination. Beyond it is another dimension - a dimension of sound, a dimension of sight, a dimension of mind. You're moving into a land of both shadow and substance, of things and ideas. You've just crossed over into the Twilight Zone.
Sorry moderators I just couldn't resist it, this thread is really way out there
MTS2000des
5B2_BEE00 Czar
HI
if the radio is flashed for it, you can enable singletone signaling on one of the side buttons as a repeater access tone. the problem is not all MTS2000's come flashed with it. what is the flashcode on the radios in question?
dss261263
UK
Hi
Excellent thank you all for your reply's, I have a business radio license for the UK, and will check what frequencies I use with Ofcom thanks, HI MM, to boldly go where no mans been before, and I bet you have, not really out there, I have spent a lot of time etc researching things I have no real background in this, so I am here asking the experts, but will re-read the post and adjust to suit, have a good one, HI Mts2000Des, excellent thanks for the informative reply, I have listed what info I have some are top display and others buttons on the front,
Codeplug-000B
Firmware-05.44
Package-h38
Flash 001008-000000-0
Hi Gary 123 thanks, I checked my data and the freq I use is within my license the 449.3125 etc, thanks, I personally use earbone earpieces especially for night clubs and football but not everyone have these and would be willing to pay the price for these, and a tone would be ideal for alerting everyone of any issues and if different tones etc could be used this would be easy to follow, thanks again and have a great night chaps.
David
