Multicoupler versus splitter
Bonkk083
Union, SC
Will a tv splitter be better for 2 scanners than a multicoupler without noticing loss
Bonkk083
Union, SC
Did you receive your Stridsberg yet?
Yes but can't tell if it's working lately I put the frequencies I had in my 996 into the 536 and not picking up anything and service types are set but custom is checked also
sonm10
Central MN Monitor
Sauk Centre, Minnesota
Myself and a couple others use a TV splitter with a LNA in front to make up for the loss. Only issue is the F to anything adapters.
dave3825
Suffolk County NY
To be honest I do not know. I did just read someone had one with a green led and one with a red led.
Napalm
Lake Co, Ind
This is working well for me for milair and a 225-400 filter and lna
Bonkk083
Union, SC
Will the Stridesburg hurt digital 800 performance I put the antenna that come with the scanner and receive signals 30 miles away but when I connect the outdoor antenna through the Stridesburg and get nothing could that be the noise ratio
dave3825
Suffolk County NY
How does the outdoor do direct to the scanner? Should be exactly the same. If stock antenna is doing better than outdoor, then there may be a problem
gmclam
Fair Oaks, CA
Is there a difference between the outdoor antenna connected directly to the scanner versus through the Stridesburg? What's likely happening is the outdoor antenna is picking up a (non-desired) strong signal and that's effectively reducing your receiver's sensitivity. I have strong signals from paging, cell towers, AM/FM broadcast and the like near me, so I've added filters to reduce the strength of those signals between the antenna and the amplifier (Stridesburg).
Bonkk083
Union, SC
I hooked the telescopic antenna to the Stridesburg and it picked up better on the 996 not to good on the 536
