Multiple 2-tone paging
Rheems1
Dover, Pa
Is there a way to set up different 2 tone paging alert based on zone? What I would like to do is set Zone 1 for our county and monitoring North Fire-ground channels and alert for my department only, I am good with that (after much trial and error) but I would like to make Zone 2 monitor south fire-ground channels (obviously with dispatch) and alert for 3 departments one of which is mine. Is there a way to set this up? I would think it would require 2 different two tone paging profiles but I have not dug in to see if you can create 2 separate paging protocols.
buddrousa
This is even posted in the Motorola Pager information.
1. Scanning and 2tone page tones are not a good idea.
2. Most Commercial Pagers can use up to 4 page codes on a Frequency.
3. I would only do this if the Dispatch Frequency is the same for all 3 Departments.
Short Paging Lesson 2 tone works on 2 things 1 TONE 2 Timing (Tone Length) any of the 3 are wrong Pager will not ALERT Scanning can cause you to miss 1/2 second of a tone and you miss the ALERT.
Rheems1
Dover, Pa
I should have mentioned it is all the same P25 Trunking system, I just want dispatch to alert on 2 more companies in Zone 2 but not Zone 1. I may have figured it out
buddrousa
2tone paging on a P25 Trunking System is not a PROJECT for a Do it Yourself. You are talking Life Safety that puts you 100% liable for Communication Alerts or lack of Alerts this should be done by a LICENSED TRAINED RADIO SHOP.
