Currently have CB antenna (attached to side of home) and multi-band scanner monitoring antenna (mounted on chimney) on the one side of the home about 20' apart. Thinking of adding a GMRS antenna (J Pole) to the home (If I decide to move forward getting a GMRS license and other equipment) connected with LMR 400 cable.
My question is adding a GMRS antenna or any other antenna (possibly digital tv).
- Looking for advice of placement location in relation to other antennas?
- Minimum distance apart?
- Other things I want to consider?
- Thought about putting an attic antenna for GMRS or the Digital TV. I am sure there are downsides to this. Years ago I had a CB antenna in the attic and it worked pretty well - before I was able to get the outside installed.
Thank you
Thank you
