Multiple IDs on a single frequency.
colehw
Willis, TX
OK. Now I'm getting a COM error because the radio isn't on and i'll be unable to turn it on even with brand new alkaline batteries.
hiegtx
Dallas, TX
I found the driver but instead of it saying 325P2 it's says 996P2.
It's the same driver for all the late model Uniden scanners. Works with my 436HP, 536HP, HP-1, 325P2, SDS100 & SDS200.
hiegtx
Dallas, TX
If you cannot turn it on except when using external power, then something is wrong with either one of the batteries, or with the battery circuit in the scanner. Using brand new alkalines, that should rule out a bad battery. Even though you can't charge them, they should run the scanner.
I know you've probably already checked, but re-check to make sure the batteries are seated in the correct positions.
It should not make a difference, but, with the scanner powered externally, go to the Menu
Scroll down to Settings, and press E to select that.
On the Settings menu, scroll down to Battery Options then press E to select it.
On the Battery Options menu, select Set Battery Save
I have my 325P2 set as Off for that. Again, this should not have any effect on powering with batteries, but try it any way, just in case.
colehw
Willis, TX
Well I can’t use alkaline batteries so I’ll just go to the store and get NiMh batteries instead.
tvengr
Well Known Member
Baltimore County, MD
Disconnect the cable and turn the radio off. Connect the cable. It should ask Start Charging ? Press the ./No button. Leave the cable attached. Turn the radio on. With the charging turned off, it is safe to use alkaline batteries.
colehw
Willis, TX
What if the radio doesn't turn on with alkaline batteries? Would I need a powered port?
colehw
Willis, TX
I tried with brand new Alkaline batteries straight from a new box. It still refuses to work.
tvengr
Well Known Member
If the radio does not operate on battery power with good batteries, it looks like you have a problem with the battery circuit in the scanner. I don't see any settings that would affect that. Did you have the charge set to off with the alkaline batteries? It will detect batteries that cannot be charged and display Battery Error. The fact that the radio comes on for a short time using batteries indicates to me that you probably have a failure of an electronic component. Is the radio under warranty? I think it is time to send it in for repair. Do other members of the forum agree with my diagnosis? I welcome your comments.
colehw
Willis, TX
I don’t know if it’s under warranty. I got it from offer-up for $130 because the seller said it wouldn’t power on with NiMh batteries that he only charged for 10 minutes or alkaline cells and seeing how it’s outdated for quite a while. The warranty is most likely void or gone.
colehw
Willis, TX
The battery problem was probably the reason you got it so cheap.
Yeah. Not like I can do anything about it. I tried all sorts of things including hooking it up to my powerbank to make it at least portable. I wanted to test every connection with a multimeter but it might make things worse or not resolve it.
colehw
Willis, TX
Wait I saw an article about with windows 8.1 / 8.0 and USB programming. I don’t think it could be an issue but who knows.
hiegtx
Dallas, TX
The failure to operate with batteries is not something you could correct with programming. Probably your next step would be to send it in for repair. You can start that process on this page:
The cost to repair a 325P2 is $89.95 (that includes $10 for return shipping. You would also pay for the shipping to send it in.) The cost for a new 325P2 is around $350.00. Of course, as long as you can power it externally, it would still be usable, but not very portable.
colehw
Willis, TX
I don’t really have that amount of money. Besides i’m sure it can be fixed somehow. It might be a simple mistake or a issue with internal charging. I accidentally left the NiMh batteries at my mom’s house so hopefully once I get those back it’d work.
Thankfully i’m not on the move often and it seems to work fine in a car usb charger.
