MURS base station?
JNE78
Hi, new to radios and have a question about base stations.
We have the Wouxun KG-805M MURS radio handset. We'd like to have a base station unit in the house that can communicate with the handsets. We have some acreage and would be used when a family member is out in the field or woods.
Is this possible? If so, what models should I look at?
Thank you,
ko6jw_2
Santa Ynez, CA
MURS is limited to 2 watts. You might want to consider GMRS with higher power and base/mobile radios. It requires a license. No test - just pay money to the FCC. License covers a family group.
The challenge with MURS and base stations is that MURS is limited to 2 watts, no exceptions. There are not many 2 watt mobile radios that have the necessary FCC type certification.
If you want to follow the rules for MURS, then you must stick inside those limitations. If you don't care about rules, there are options.
But let's stick with the legal MURS stuff, just for the sake of argument.
There are multiple models of these two radios. Make sure you get the MURS version:
Those will do what you want.
But if you really want to make these sing, you need to put up a good base station antenna and feed it with appropriate coaxial cable. There are height limitations on the antenna, so make sure you keep that in mind:
§95.2741 MURS antenna height limit.
The highest point of any MURS station antenna must not be more than 18.3 meters (60 feet) above the ground or 6.10 meters (20 feet) above the highest point of the structure on which it is mounted. MURS station antennas must also meet the requirements in §95.317 regarding menaces to air navigation. See 47 CFR 95.317 and consult part 17 of the FCC's Rules for more information (47 CFR part 17).​
But that gives you a lot of options. Simply getting a good VHF base antenna outside and in the clear will make a huge difference. Don't get hung up on transmitter power output, it doesn't make as much difference to range as people will tell you.
There are other options, but they rely on -old- radios that will be difficult to find and even more difficult to program. There were some old Motorola MaxTrac 2 watt VHF mobile radios that met the 'grandfathered' requirements and would be legal to use on MURS. However, they were few and far between when new, and what few were out there were gobbled up by people who knew what they were.
There was also an old Radio Shack 'business band' mobile radio that was sold for a few years that met the requirements, but again, those were snatched up quickly.
JNE78
Thank you all for the information. I like that MURS will be sufficient for our needs. GMRS costs more plus it has rules.
I'll check out that base station, it may be what we're looking for as in something to keep in the office at home.
GlobalNorth
Fort Misery
Before you commit to MURS or GMRS, take time to actively monitor both systems. I got a GMRS license for Jeep runs, but it is nearly unusable in the city due to the businesses, radio hobbyists, children on FRS, and the electro-anarchists who love spew their obscenity laced rants at anyone and everyone. Even out in the boonies, I get more GMRS traffic than MURS.
Outside of getting close to Wal-Mart, I rarely hear anyone on MURS and the two watt limit is perfect for campsite use, spotting a line when 4-wheeling, etc.
ecps92
Taxachusetts
MURS has rules as well, one being 2 watts where-as GMRS is 5-50 watts
jhooten
Paige, Republic of Texas
Model number 19-1210. I have two. They work well BUT are wide band only so they can only be used on the
154.570 MHz (20.00 kHz)
154.600 MHz (20.00 kHz)
channels
They occasionally turn up on ebay.
iMONITOR
Silent Key
S.E. Michigan
When you say "sufficient for our needs", what distance are you hoping to achieve as the crow flies? Any tall trees, hills, power lines or structures in-between point A and point B?
JNE78
When I say rules, I mean:
No coded messages with hidden meanings
Must identify using FCC-assigned call sign at the end of transmissions and at periodic intervals during transmissions
No more than 2 miles, typically less than that. There were will varying terrain such as fields and trees.
iMONITOR
Silent Key
S.E. Michigan
They might not be reliable at 2 miles. Typically I'd say 1 to 2 miles, but 2 miles would be under ideal conditions. Make sure you buy them from a dealer that accepts returns and issues refunds it they don't perform.
JNE78
or MURS-V1 MURS Radio
I just need one that can monitor the weather as well or at least allow me to tune into local NOAA.
