As a creature of habit, I tune over to 1030 WBZ to fall asleep, like I always do. But the semi-local class D Spanish station is still broadcasting at full power, several hours after sunset! A disappointing ending to a very disappointing day.
Jim thanks for this. I read in the instructions about enabling MW notch via internal jumpers, but how do I use the unit for adjacent interference? Could you kindly enlighten me? Just a mere manipulation of controls?The MFJ-1025, out of the box, only works down to 1.8 mhz. Have done the modifications on it to work down on the broadcast band. It works well for nulling unwanted stations.
Ridge, you could do the same with your Timewave without any modifications.
Jim
Yes. I suffer the same thing here in San Francisco. I enjoy 920kHz out of Modesto at bedtime with their oldies, but the local station on 910kHz bleeds in especially during commercials. With my two bedside DXrs, my sx-88 with its bandwidth selector, and my Realistic DX-160 with its awesome selectivity on MW, both with antenna trimmers that I can use to weaken adjacent power, I can get a manageable copy.
There's another station I like a lot out of Ventura, Ca. on 1520kHz, but the same bleedover from a local Asian station on 1510.
It seems like certain stations are immune to power-down.
Thanks for the help! Is IBOC where there are "rushing" sounds on either side of their frequency? If so, no, 910 doesn't use that. The only station I know of that does have that characteristic is a sports station on 1050. I gave the Timewave a go last night after reading Jim's post, but on the R71A at the desk and it did seem to cut about half the bleedover. The only small problem is I listen to those stations at bedside with one of the other two receivers and I'd have to jump up out of bed to adjust the Timewave any time I changed frequencies. OTOH I could just stick to one frequencyThat station on 910 may be running IBOC.![]()
If it is, all the selectivity in the world isn't going to help.
Have the MFJ 1026 here (did the LW/MW mods) and it does help cancelling out unwanted stations and noise. It will only cancel out one other undesired signal. If, for example, the noise is from multiple sources... forget about it. The controls require some manipulation to get good results. The key seems to be to adjust the respective gain controls to get the desired signal on the main antenna and the undesired signal on the "noise" antenna at the same strength and then adjust the phase control for null.
If the undesired stations are on enough different azimuth your loop should be able to null them out.
And you are right about the loop-it surely does help with null.
Nah I do ok with those receivers especially the SX-88, I just switch the band width knob to 5kHz and it kills all the bleedover. The DX-160 is trickier-I adjust ant. trimmer for weak instead of peak, then tune a little away from the local flamer on that one. Plus that old 160 really is very selective in MW.
Would like to take the Palstar and the MFJ out to the park sometime and experiment with longer wire antennas.
Good idea... get away from all the noise.
Find a suitable spot and simply lay as much wire as you can right on the ground. The longer the better.
Aim the end of the wire in the direction you want to DX.
See post #5, click on the link to "hard-core DX" and then in that article click on the link "MFJ needs to be modified" for some mini-DXpedition ideas.
But I haven't taken the MFJ out yet and experimented with two antennas.
