My Autistic Son
Earrings
Anamosa,Iowa
I'm trying to find someone professional to help my autistic son with a handheld digital radio scanner fire police VHF FM EMS Ham 2 way transceiver dual. My son can't read or write but love to listen to the scanners at my friend's home. So for Xmas I picked one up.I have no idea what to do with it to make it work. CAN ANYONE HELP ME & MY SON?!!!
Cashanova48
GMRS callsign WSAF780
What brand and model is the scanner? Does it have a "Band" button or something similar. If so, press it until it says something like "public saftey". If you live in an area the scanner will work, then the scanner should start receiving traffic (to an extent). Hard to tell without knowing the brand or model.
Earrings
Anamosa,Iowa
It's a handheld Digital radio scanner fire police VHF FM EMS Ham 2 way transceiver on the front it says BAOFENG- UV-5RM PLUS
Whiskey3JMC
Google-Foo Ninja 4 Hire
Simulcastylvania, TE
Hate to be the bearer of bad news but you're not going to be able to pick up your county's police or fire with a Baofeng. They operate on the trunked radio system linked below. You'll need a P25 Phase-II capable trunk tracking scanner to pick up said trunked system, see list here for capable receivers. Talkgroups ID'ed as mode "T" are clear and can be monitored. Mode "TE" talkgroups are fully encrypted and cannot be monitored with any receiver not intended to operate on the system
And for your perusal, an overview on how trunked radio systems work:
I'd return the Baofeng for a refund ASAP. It has transmit capabilities and you wouldn't want you or your son inadvertently transmitting on any frequency, that could lead to trouble
D31245
FN42
Is your friend local? Perhaps he/she can guide you on what to purchase if it fits your budget and perhaps can help program the scanner.
Earrings
Anamosa,Iowa
I already asked they had it done before they received it. Deal included at cost scanner & programming.
Earrings
Anamosa,Iowa
Wow! No wonder it was so cheap. Well poo any recommendations way under budget??Maybe just point me in the right direction or 2 different area I could look into. Thank you
Whiskey3JMC
Expect to spend about $300+ for a P25 Phase-II/TDMA capable scanner, receiving Phase-II isn't cheap. Alternatively you could explore a software defined radio but these require a computer and software to drive it. Plenty of info about that on the Software Defined Radio forum.
Your son could listen to online feeds on Broadcastify, however no one's providing any feeds for your county
Cashanova48
Non the less if the county uses simulcast. Then most ~$300 scanners won't do it, sadly. If your county uses talkgroup modes with a "D", then a phase 1 scanner will do the trick.
Cashanova48
I would not give your son a baofeng. That is a transceiver not a scanner. He could inadvertently transmit on unlicensed or public safety frequencies.
However, there are multiple ways to make it impossible for the radio to transmit, given you have the programing software and a programing cable. The Baofeng is a good tool to test if you want to get into Amature radio, but not a great tool for radio scanning.
  • Like
Reactions: wtp
maus92
OCMD
To start, this is a link to stream Iowa Dept of Public Safety for your area:
I'm seeing some fire department analog VHF frequencies for Jones County which the Baofeng radio could be programmed to monitor. The police seem to be using P25 conventional exclusively, so the Baofeng will not work for those.
I would look into a Uniden 325P2 for your area - probably the best solution, but not cheap.
Guldnerk
Benton County, IA
Jones County is still transmitting conventional.... for now. Actually quite a bit of traffic on those channels and I pick them up clear as day here in Benton County.
tvengr
Well Known Member
Baltimore County, MD
What scanner does your friend have? If you are close to each other and purchase the same scanner, it may be possible to clone the scanners or have your friend program it for you.
Guldnerk
Benton County, IA
Unfortunately before too long they will all be on the SARA network along with the counties around it so only an SDS will work. Reading their county minutes they haven't moved because of budget concerns and hasn't been mentioned since 2022.
