I thought I would share the solution I landed on, so that someone else might benefit from it,
the problem
uniden bearcat Cb in my basement. Mag mount K4O antenna outside my basement window. Issue. How to get good swr readings
i got near perfect readings by doing the following
bought a steel grid small round garbage bin- like you would use at an office
tipped it upside down. Mouth on the earth.
bought two large steel bowls. Like salad bowls but large
put one inside the other, sat them upside down on the garbage bin, like a hat
got two large round steel cookie trays. Put them both on the top of the hat- ,made them overlap to get more area. Used duck tape to make sure the whole thing hung together.
put the mag mount on the cookie trays
readings are excellent. Near perfect
bought all materials at dollar store. Less than 20 dollars
the problem
