My Unication G5 pager is lit!
policefreak
Berlin, NJ
So with the latest firmware and PPS it looks like we are back to disco. 🤔 When i turn off my Unication G5 after some time the 3 lights come on and stay on. When I turn the pager back on it takes about 1 minute for the pager to actually boot up. I remember this with other FW and PPS versions. Is there a fix to stop this happening all the time? It does drain the battery.
kb8q
Ferndale, MI
I had a G5 that did the same thing after updating the firmware to V2.02. It was under warranty. Sent it back to Unication and they reverted the firmware back to 1.3. That stopped the LED issue. However, I needed to be able to program G5/V, G5/U and G4 using the convert model feature. So, I wound up going back to V2.02 to be able to use PPS 1.40 just live with the errant behavior.
K9KLC
Southwest, IL
They are staying on until I turn the unit on, or after quite a few hours they go off. Hey, has a battery pull alleviated the issue for anyone?
Ok I noticed every now and then mine does that but usually goes off in a minute or so, and, it doesn't do it all the time. Honestly I haven't seeing for a while now. I have 2.02 on both my G5's and obviously using the latest PPS.
