N.H.S.P. HQ frequency
bobm1940
Manchester; N.H.
NHSP frequencies
I tried that site put the frequency in no luck. I pick up troop A and B with no problems. I don't know what I could be doing wrong
jmarcel66
Concord, NH
Your location may preclude you from hearing them. It becomes critical w/P25 where you are for reception; especially if hills get in the way. Troop-A for me is tough in Concord.
156.210 is the correct frequency as of this morning for Hq/Troop-D.
bobm1940
Manchester; N.H.
NHSP
That may be the problem because troop A&B work just fine. Maybe I will take a ride up to Concord to listen for myself at least I will know I have it in scanner. Thanks for answering.
ronhl
Live Free or Die St.
Im in Manch and having the same issue too, used to picked them up loud and clear in P-25. Wonder if they changed somthing like the transmitting tower location or power output or maybe the antenna to be more directional vs. omni-directional type.
jmarcel66
Concord, NH
You may be right. All of NHSP except Troop-F (Kindof) are multi-site simulcast. Without anyone knowing (except NHSP I assume), a site may have gone down or developed an issue. So in Manchester, it's become poor, while here in Concord, I get them fine. The pro's and con's of listening to a simulcast system.
ronhl
Thanks John......and just to add I put my 197 in analog mode and their digital signal barely breaks squelch. Makes me think they would have the same problem if say a TRP A or B cruiser switched over on TRP D, interesting. Could be unrelated but I remember a while back the Manch TRS had to reduce power output due to interference with another TRS because they shared one of the frequencies.Or maybe they want the best bang for their buck regarding their assigned coverage area--- Concord north and the I-89 corridor and terain.
