Ok, I've loaded my set of local frequencies, and pretty happy with the current programming.
When scanning, it appears that sometimes the scanner will land on a frequency that is programmed and will identify it according to the program, for example, it will display 155.XXXX - Tucson Police Department Sector XXX. Other times, it will land on this same frequency, and display some sort of generic identifier like Arizona - Public Safety. I assume that this is because the same frequency is found in both my custom programming, and in Uniden's Bear Tracker list, which is preloaded.
What I want is to force the scanner to display the correct ID data if it lands on a frequency that I've identified, and to display this sort of generic data only if I haven't programmed that frequency yet. How do I accomplish this?
