NAC Entry ??
druhe
Southwest Pa
How do you enter NAC 3F8 ? If this is not possible, is NAC 0 the same as CSQ ?
Thanks in Advance
hill
Middle River, MD
F7E is carrier squelch on P25, but don't know how it works in the pager and not a real subscriber radio.
druhe
Southwest Pa
Is F7E hex or decimal ? When entering as decimal the program won’t accept it.
dlwtrunked
It is actually designated "Any NAC". I am nsure what happens if no NAC is transmitted.
Thanks in Advance
Why is it not possible? Read the Unication PPS help when you are programming the pager it it explains it. I use F7E (which is CSQ) as said in the help and it works fine.
druhe
Southwest Pa
Let me see if I got this, if the NAC is 302 then its decimal, and if its 3E8 its hex ?
302 = 12E
1000 = 3E8
jtwalker
Gettysburg, PA & Fenwick Island, DE
302 = 12E
1000 = 3E8
No. But if it is 12E or 3E8 then it is definitely not decimal. The values 302 or 1000 could be either.
Wherever you are seeing these should be marked as to which they are, no? You have to look at context in which you see these values to know which they are.
druhe
Southwest Pa
The list just has them marked as NAC 302 & 3E8. I have seen other lists where the NAC (not this particular system) is listed as dec or hex, hence my confusion
jtwalker
When I say look at the context, I mean look at the entire list of values. If all the values don’t have A-F and only 0-9 then I would lean towards it being a decimal list of values.
