XTS3000 NAS Scan issue
playzgod
Miami, Florida
I have been able to program my xts3000 to NAS. But I notice that I only pick up audio when it is in monitor mode. I went down to Monroe county a couple hours ago and it worked fine with out being in monitor mode, showed me ID's and audio was great, but for Miami dade Im only able to pick up audio in Monitor. Not sure if its something with the radio but it does bother me. Any help would be greatly appreciated.
chrismol1
P25 TruCking!
huh? What does monitor mode mean for this radios NAS programming. Meaning you press a programmed monitor button? You're scanning the trunked freqs in a conventional scan list? With conventional talkgroups or listening to all with a nac of F7E?
playzgod
Miami, Florida
Correct the programmed monitor button, I am listening to the trunked freqs on a conven scan list, its the regular nac of 293
Do you think if I send you the CP maybe you can mess with it?
chrismol1
P25 TruCking!
F7E is the NAC that un-squelches to all p25 transmissions, its the equivalent to CSQ on analog transmissions. As long as you assign that nac to each frequency it will receive any transmission.
This isn't actually referred to as non-affiliate scan as you are not receiving a programmed trunked control channel that instructs the radio to tune to the current frequency of a trunked talkgroup as how NAS trunking works. You are simply scanning all the frequencies programmed and radio unmutes to the first transmission it receives regardless of talkgroups. Although you can do what you are doing while programming a talkgroup conventionally where it scans the frequencies and unmutes for that talkgroup under astro systems astro talkgroup list and assign to conventional personality
chrismol1
P25 TruCking!
although doing the conventional talkgroup scan method only scans 1 talkgroup at a time so on less busy system or only the frequencies for one site or so you could do the CSQ of F7E and receive everything. Only when it gets busy and you risk missing transmissions of one talkgroup you want to monitor its more beneficial to program the scan list channel to a talkgroup. You could program talkgroup as a menu item to do this, with the ones you want. While doing this you also program a talkgroup of 65535, which is the wildcard talkgroup equivalent of F7E for a nac. So you can change up to the talkgroup you want, say during an incident and then change it back to 65535 which is will receive any talkgroups that scan lands on
playzgod
Miami, Florida
this is my radio and an example of what is going on. first 15 second are with out the programmed monitor button
chrismol1
P25 TruCking!
Try changing the digital modulation to CQPSK, change all the nacs to F7E. Other than that if it still sounds like that its likely off frequency in need of a tune up
BigLebowski
Piedmont NC
F7E as a "Receive All" NAC was never implemented in the Astro line. You need to set the channels to "Digital CSQ".
BigLebowski
Piedmont NC
It can be whatever you want as long as you set it to Digital CSQ, or alternately set it to the actual site NAC which you can obtain by listening to one of the voice channels with a scanner.
playzgod
Miami, Florida
Did what you told me to do and wrote to the radio, still only grabbing audio when it is on monitor.
natedawg1604
Colorado
Are you seriously using a Moto radio to scan individual frequencies on a trunked site? If so, why....? That is NOT NAS, throw this thing away and get a XTS 5000, or better yet get a Harris P or XG series and it will be almost impossible to screw up NAS.
